Helpful Regular Expressions for Repository Administration
The following reference is an abridged list of regular expressions that are particularly helpful in forming text field constraints that will be applied in the web client and Windows client. Additionally, it contains a table with character class syntax that is used for field constraints in the web client and Windows client, but not in other Laserfiche products.
Field Constraints
When specifying constraints, you may want certain characters to be automatically assigned to a field, which can be done by typing the characters where you want them to appear in the field. The exceptions are characters that have been reserved for use by regular expressions. A list of these characters can be viewed from the Symbol column of the table below. Reserved characters can be automatically assigned to a field by placing a backslash prior to the reserved character. For example, if your organization decides that phone numbers should be specified as (310) 555-1212, you would specify the following expression: \(\d\d\d\) \d\d\d-\d\d\d\d. Notice that the parentheses have been escaped with a backslash, while the dash has not been. Both parentheses and dashes are reserved characters. However, dashes can never be used without brackets, therefore they are treated as a regular character and do not require a backslash. Assigning this constraint to a field will create visual indicators as to how field data should be formatted. In the example stated above, blank fields will look like "( ) - ." As you can tell, users will not need to type the parentheses or the dash when specifying a phone number. These symbols are automatically shown to indicate what the format of a phone number should look like.
The following table describes each regular expression that can be used to establish a pattern that field data must match.
| Name | Symbol | Description |
| Any Character | . | Any single character. |
| Character in Range | [] | Any character inside the brackets. For example, the expression [abc123] allows only any of the following characters: "a," "b," "c," "1," "2," or "3." |
| Character Not in Range | [^] | Any single character except for those inside the brackets. For example, the expression [^abc123] allows any character except for: "a," "b," "c," "1," "2," or "3." |
| Range Character | [-] | Any single character contained within the specified range. For example, the expression [0-9] allows only any number that falls between 0 and 9 (inclusive), and the expression [A-Z] allows any capital letter. |
| Beginning of Input | ^ | Requires the beginning of a string of text to match the expression that follows this symbol. For example, the expression ^[abc123] allows only field data that starts with either "a," "b," "c," "1," "2," or "3." |
| End of Input | $ | Requires the end of a string of text to match the expression that follows this symbol. For example, the expression [abc123]$ allows only field data that ends with either "a," "b," "c," "1," "2," or "3." |
| Or | | | Requires one of two expressions. For example, the expression he|she allows only field data that is set to either "he" or "she." |
| 0 or More | * | The preceding expression can occur zero or more times. For example, the expression [0-9]* allows any set of consecutive digits or no digits at all. |
| 1 or More | + | The preceding expression can occur one or more times. For example, the expression [0-9]+ allows any set of consecutive digits. |
| Previous Statement is Optional | ? | The preceding expression is optional. Data satisfying the expression may be specified as field data or a user can choose to not enter it. For example, the expression [0-9][0-9]? allows only a single or double digit number. |
| Group | () | Groups an expression together. For example, the expression (t|T)he allows only field data that is set to either "the" or "The". |
| Escape Character | \ | Either an abbreviation (see table below) or that the next character be translated literally. This character should only be used for reserved characters, such as those listed under the Symbol column of this table. For example, \d+ allows one or more digits, while \d\+ allows a digit followed by a plus sign. |
| Alphanumeric | [[:alnum:]] | Any alphanumeric character. |
| Alphabetic | [[:alpha:]] | Any alphabetical character in the following ranges: a-z and A-Z. |
| Space/Tab | [[:blank:]] | A space or a tab. |
| Digit | [[:digit:]] | Any digit. A valid character is a whole number from 0 to 9. |
| Lower-case | [[:lower:]] | Any lower-case character (i.e., a-z). |
| Printable | [[:print:]] | Any printable character. |
| Punctuation | [[:punct:]] | Any punctuation character. |
| Space | [[:space:]] | Any whitespace character. |
| Upper-case | [[:upper:]] | Any upper-case character (i.e., A-Z). |
| Hexadecimal | [[:xdigit:]] | Any hexadecimal digit (i.e., 0-9, a-f, or A-F). |
| Word | [[:word:]] | Any word character. Valid characters are all alphanumeric characters and underscore. |
| Decimal Digit | \d | Any single decimal digit. Corresponding syntax: [[:digit:]] |
| Non-Decimal Digit | \D | Any character except for a single decimal digit. Corresponding syntax: [^[:digit:]] |
| Space | \s | A single space character. Corresponding syntax: [[:space:]] |
| Non-Space | \S | Any character except for a single space character. Corresponding syntax: [^[:space:]] |
