Plan Information
The Plan page in Laserfiche Cloud Account Administration lists the plan-specific features for your Laserfiche Cloud account. For features with limits (for example, API calls or number of licensed users), this page also lists how many have been used of the maximum.
For more information about Laserfiche plans, please see Laserfiche Cloud Pricing. For information about general Laserfiche service limits, see Service Limits
Overview
The following features and limits may be listed for your Laserfiche implementation. If an item is not present on the plan page, your plan does not include that feature or component.
Users
Lists the total number of users supported. This number is further broken down by user type (full, participant, and community). See Managing Users for more information, including determining how many user licenses are currently available.
Service Principals
Lists the number of service principles supported. See Service Principals Overview for more information.
Storage
Lists the total amount of storage available in GB. See Storage Usage, below, for more information.
Public Portal
Lists how many public portal views are supported per month. See Public Portal for more information.
Forms Portal
Lists the number of public form submissions supported per month. See Making a Form Public for more information.
Laserfiche API
Lists the number of supported Laserfiche API calls. See Building Custom Integrations with the Laserfiche API for more information.
Transcription
Lists the number of transcription hours for audio and video are supported per year. See Working with Audio and Video Files for more information.
Process Automation
Specifies whether the plan supports process automation features. See Process Automation for more information.
Docusign Integration
Specifies whether the plan supports the Docusign integration. See Docusign for more information.
Records Management
Specifies whether the plan supports records management features. See Records Management for more information.
Audit Trail
Specifies which Audit Trail tier the plan supports: Starter or Advanced. See Auditing for more information.
Direct Share
Lists the maximum supported file size and share expiration date for documents shared via Direct Share. See Sharing Documents through Direct Share for more information.
Lookup Tables
Specifies lookup table limits by number of tables and number of rows per table. See Lookup Tables for more information.
Just-in-Time Provisioning
Specifies whether the plan supports Just-in-Time provisioning. See Just-in-Time (JIT) Provisioning for more information.
SCIM
Specifies whether the plan supports SCIM (System for Cross-Domain Identity Management). See Configuring SCIM in Laserfiche Cloud for more information.
Max Repositories
Specifies the maximum repositories supported. Professional and Business Tier Licenses are eligible for multiple repositories either as an add-on or included with a Cloud subscription. Please speak to your Solution Provider to request additional repositories, if available under your plan.
AI Units
Specifies the number of AI units supported. See AI Units, below, for more information.
Condition Starting Events
Specifies the maximum number of active condition starting events supported.
Usage
Total Usage
Specifies how much storage you have used this month, out of your total storage available.
Per-Repository Storage
Lists how much of your storage has been used per repository this month.
Forms Portal Submissions
Lists how many submissions have been used of your maximum forms portal submissions this month.
Public Portal Views
Lists how many views of your maximum public portal views have been used this month.
Laserfiche API Calls
Lists how many calls of your maximum Laserfiche API calls have been used this month.
Transcription Minutes
Lists how many transcription minutes of your maximum Laserfiche audio-visual transcription minutes you have used this month.
AI Units
Lists the number of AI units you have used this year out of your total. A limited set of user-initiated operations can be performed without decrementing your AI usage; see Laserfiche AI Usage for more information. All other Laserfiche AI operations will use AI units.
If you have used AI units in this billing period, you can expand the Usage by service since date section to view specific usage for the following Laserfiche AI features:
  • Field extraction
  • Template selection
  • Tag classification
  • Form fills
  • Collections API queries
  • Prompt rule actions using Laserfiche AI
Note: The usage by service information is available for operations performed on or after July 24, 2026.
The number of AI units required for an operation are as follows:
  • Smart Fields (including field extraction, template selction, and tag classification): A single AI unit is used for any number of fields on a template for a single entry, or template selection for a single entry, or tag classification for a single entry. Additional AI units may be required in the following circumstances:
    • PDFs and imaged documents: If there are more than 10,000 words in the first ten pages of the document, each additional ~10,000 words over the first ~10,000 uses an additional AI unit.
    • Microsoft Office documents and text documents: If there are more than 50,000 words in the first 50 pages of text, each ~50,000 words after that first ~50,000 counts as an additional AI unit.
  • Prompt rule actions using Laserfiche AI: A single AI unit is used for each ~50,000 words of text or each ~20 images processed.
  • Form fill using Laserfiche AI: A single AI unit is used for each file extraction.
  • Smart Chat: Smart Chat does not use any AI units.
Note: AI units are always counted in whole numbers; usage will never be counted as fractions of units.
Disaster Recovery
Lists the repositories with enhanced disaster recovery support. Not all plans include enhanced disaster recovery support.
