Data Sources FAQs and Best Practices
FAQ
How are direct connection data sources different from Remote Agent data sources?
Unlike Remote Agent data sources, setting up a direct data source to a database in Laserfiche Cloud creates an immediate connection without any intermediary components. These direct connections use provided credentials to establish real-time communication between Laserfiche Cloud and your database. This approach delivers better performance by eliminating the middleware and queuing processes that Remote Agent requires. Here are the key differences:
  • Query Rules with direct connections can use raw SQL queries, while Remote Agent Query Rules are limited to the graphical user interface (GUI) query editor.
  • Query Rules with direct connections can be used in Forms Lookup Rules, unlike Remote Agent data sources
  • Query Rules with direct connections can be used with Dynamic Fields
Learn more about remote agent and direct Microsoft SQL connections.
Can I update an existing Data Source to use a direct connection?
No, you can't update existing Remote Agent data sources to use a direct connection instead.
How does security work for direct connections?
To use data sources with direct connections, your database must be accessible from the internet. Laserfiche Cloud uses fixed originating IP addresses, allowing you to add them to your allowlist for inbound firewall rules. You'll also need to provide the required connection settings for your database, including appropriate authentication credentials.
Which databases are supported for direct connections at launch?
At launch, we will support only Microsoft SQL Server, with potential support for other database vendors in the future. Please review the documentation for specific database requirements.
Can I connect to a SQL Server Named Instance?
Yes - in the server name field put your named instance in the following format:
sql.example.com\INSTANCE,$port
What ports are supported?
Right now, port 1433 is the only supported port for security reasons. If you want to access a database through a different port, please contact us through the Feedback link in the menu below your username.
How can direct connections improve my existing solutions?
Real-time, direct database queries can significantly simplify solutions in Laserfiche Cloud. For example, instead of synchronizing data from an external database into a Lookup Table, consider querying the data directly when needed. This approach can eliminate the need for data synchronization Workflows and reduce the number of Lookup Tables required. Evaluate your existing solutions to see if direct database queries could make your Workflows and Business Processes more efficient and performant.
Best Practices
Understand Laserfiche System Limits
When connecting to databases through Laserfiche data sources, be aware of system limits that may impact your solution. These important limits include:
  • Connection timeouts
  • Maximum returned rows
  • Workflow iteration limits
Note: A full list of limits is available here.
Good security starts at the database
When setting up a database account to use with Laserfiche, ensure the account has the minimum necessary access to perform the required tasks. For example, if you only need to select records from your database to display in a Laserfiche form, grant that database account only SELECT rights, and only to the necessary tables.
Use appropriate security controls in Laserfiche
Apply appropriate security to your data sources and query rules within Laserfiche to ensure only authorized users and groups have access. For example, you can restrict data source access to system administrators while limiting query rule usage to solution designers. You can also use Project Security to implement access separation where needed.
Write efficient SQL queries
When writing SQL queries, only return the data necessary for your solution. Avoid using wildcard SELECT statements, as they return unnecessary data and perform worse than queries that specifically select required fields.
Adjust your approach based on the situation
Understanding the context of your query is crucial. When using a query rule in a Form to populate a dropdown list, ensure your query returns an appropriate amount of data and consider the impact on the end user's experience. While backend Workflow processes may require more data, always aim to return only the minimum amount needed for optimal performance.
Certificate Specific FAQs
What certificate file formats does Laserfiche Cloud accept?
PEM, DER, and CER. The certificate content must be base64-encoded, and it must not include the private key.
Do I need to upload my database server's root certificate?
No. Upload only the server's leaf (end-entity) certificate. You should not upload the root or any intermediate certificates.
My database uses a self-signed certificate. What do I do?
Select Use custom certificate when creating or editing your data source, and upload the self-signed certificate. See Finding and uploading your SQL Server certificate for step-by-step instructions.
My database is hosted by a third-party cloud provider and I can't access the server directly to export a certificate. What are my options?
Contact your IT Department for options on obtaining the certificate. See "Option B" in Finding and uploading your SQL Server certificate.
What happens when my custom certificate expires or is rotated?
Laserfiche Cloud does not update custom certificates automatically. When your database's certificate is renewed or rotated, you are responsible for exporting the new certificate and re-uploading it to your data source, or your connection will stop verifying.
How do I know if my certificate is from a well-known Certificate Authority?
Check it against the Mozilla CA Certificates report or the Debian ca-certificates package list. If it's not on either list, use the Use custom certificate option instead.
