Create Entry
This activity creates an entry (a folder or document). Learn about tokens this activity produces.
To set up this activity:
- Drag the Create Entry activity from the toolbox pane and drop it in the Designer pane.
- In the Entry Name property box, type a name for the new folder or document in the text box. Click the Token button (right arrow)
to add a token. - In the Entry Type property box, select the type of entry you want the activity to create.
- In the Destination property box, specify the folder in which you want to place the new entry by clicking the Browse button (ellipsis)
to add a token. - Specify what you want the workflow to do if the destination you specify does not exist.
- Create it: Creates a new folder path.
- Create it and report a warning: Creates a new folder path, and displays a warning in the workflow instance details.
- Terminate the workflow: Ends the workflow when it cannot find the folder path, and displays an error in the workflow instance details.
- In the Creation Options property box, select any additional options.
- Return existing entry if found: If a document or folder with the same name already exists in the destination, the activity's output entry is set to the existing entry.
- Place new entry under version control: Record changes to the new document over time, creating multiple versions of the document for each new published version.
- Change starting entry to be the output entry: Set the workflow's starting entry to the new entry after this activity runs.
For an example that uses this feature across process automation, see the Migrating Laserfiche Form Tables into Microsoft Word Documents whitepaper.
Tokens for Create Entry Activity
| Name | Description | Sample Syntax |
| OutputEntry_Name | The name of the new entry. | %(CreateEntry_OutputEntry_Name) |
| OutputEntry_Id | The Laserfiche ID number of the new entry. | %(CreateEntry_OutputEntry_Id) |
| OutputEntry_Path | The folder path of the new entry. | %(CreateEntry_OutputEntry_Path) |
| OutputEntry_FullPath | The folder path of the new entry, including the entry's name. | %(CreateEntry_OutputEntry_FullPath) |
| OutputEntry_Repository | The repository the new entry is in. | %(CreateEntry_OutputEntry_Repository) |
| ParentEntry_Name | The name of the folder in which the new entry was created. | %(CreateEntry_ParentEntry_Name) |
| ParentEntry_Id | The Laserfiche ID of the folder in which the new entry was created. | %(CreateEntry_ParentEntry_Id) |
| ParentEntry_Path | The folder path of the folder in which the new entry was created. | %(CreateEntry_ParentEntry_Path) |
| ParentEntry_FullPath | The path to the folder in which the new entry was created, with the folder's name. | %(CreateEntry_ParentEntry_FullPath) |
| ParentEntry_Repository | The repository that contains the folder in which the new entry was created. | %(CreateEntry_ParentEntry_Repository) |
| Created Parent Folder | Whether the Create Entry activity created the folder in which the new entry was placed. This token can have one of two possible values: True or False. | %(CreateEntry_Created Parent Folder) |
The "CreateEntry" portion of the syntax changes to match the activity's name.
Note: All non-alphanumeric characters, except underscores, are removed from the name. For example, if you rename the activity "New *Sales* Document", the syntax for the OutputEntry_Id token will be "%(NewSalesDocument_OutputEntry_Id)".
