Rename Entry
Rename Entry activity
This activity renames a Laserfiche entry. Learn about tokens this activity produces.
To set up the activity:
  3. In the New Entry Name property box, type the entry's new name. Click the Token button (right arrow) Right arrow to add a token.
  4. In the Entry to Rename property box, select the entry you want this activity to rename. Learn more about selecting an entry
Tokens for Rename Entry Activity
Tokens
OutputEntry_Name The new name of the renamed entry. %(RenameEntry_OutputEntry_Name)
OutputEntry_Id The Laserfiche ID number of the renamed entry. %(RenameEntry_OutputEntry_Id)
OutputEntry_Path The folder path of the renamed entry. %(RenameEntry_OutputEntry_Path)
OutputEntry_FullPath The folder path of the renamed entry, including the entry's new name. %(RenameEntry_OutputEntry_FullPath)
OutputEntry_Repository The repository the renamed entry is in. %(RenameEntry_OutputEntry_Repository)
The "RenameEntry" portion of the syntax changes to match the activity's name.
Note: All non-alphanumeric characters, except underscores, are removed from the name. For example, if you rename the activity "Standardize/Names", the syntax for the OutputEntry_Id token will be "%(StandardizeNames_OutputEntry_Id)".
