Retrieve Field Values
Retrieve Field Values activity
This activity retrieves the template name and field values from an entry and returns tokens for those values that other activities in your workflow can use. Learn about tokens this activity produces.
To set up this activity:
  3. In the Fields property box in the properties pane, click Select fields to retrieve… to select the fields you want to retrieve values from.
  4. In the Choose Field dialog box, select the fields you want to retrieve a value from.
    • Name: Type a field name.
    • Template: Display fields associated with a specific template.
    • Only show selected fields: View only the selected fields.
  5. Optional: Select or clear all fields by selecting Select all / Clear all at the bottom of the dialog box.
  6. If the selected field allows for multiple values, click the No values link next to the field to configure the values the activity will retrieve.
    • All values (as a multi-value token): Stores all of the values assigned to the field in a multi-value token.
    • The values at the following indices: Specify the index number of a value in a multi-value field that will be stored in a token. Values are given an index number according to the order in which they are added to the field. The higher the number, the newer the value.
      Note: The Assign Field Values activity may change the order of values in a multi-value field so that the indices do not reflect the order in which values were added.
      • Leave the Closedstart option so that you can retrieve a value from the start of a multi-value list. Specifying an index value of 1 retrieves the first value in the list, 2 retrieves the second value, etc.
        Start option
      • Select the start option (so that it says end) to retrieve a value from the end of a multi-value list. Specifying an index value of 1 retrieves the last value in the list, 2 retrieves the second to last value, etc.
      • Optional: Select Add another index to retrieve additional field values.
  7. Click OK.
  8. In the Field Value Source property box, select the entry you want to retrieve field values from. Learn more about selecting an entry
Tokens for Retrieve Field Values Activity
Tokens
Template Name The name of the template assigned to the entry. %(RetrieveFieldValues_Template Name)
Field Name A token is created for each field retrieved. The token name is the same as the field name. If the field is a multi-value field, the field name is followed by _All.
%(RetrieveFieldValues_Field1)
%(RetrieveFieldValues_MultiValueField_All)
The "RetrieveFieldValues" portion of the syntax changes to match the activity's name.
Note: All non-alphanumeric characters, except underscores, are removed from the name. For example, if you rename the activity "Get: Info!", the syntax for the Date field will be "%(GetInfo_Date)".
