Add Sticky Note
This activity adds a sticky note to a page of a Laserfiche document. A sticky note is a small, movable note that contains text. When a user selects the sticky note on a Laserfiche document, a text box appears, where the user can view and modify the text depending on the user's access rights. Learn about tokens this activity produces.
To set up this activity:
- In the Sticky Note Options property box, configure settings for the sticky note using the following options:
- Sticky note: Type the text that will appear on the sticky note. Click the Token button (right arrow)
to add a token. - Color: Select the sticky note's color.
- Page: Select the page on which you want to place the sticky note. Click the Token button (right arrow)
to add a token. - Location: Select where the sticky note will appear on the Laserfiche document. Select Custom to place it on X and Y coordinates (in pixels) starting from Top/Left.
- If you have two sticky notes in the same location, use Merging to select how you want to display the new sticky note.
- None: Places the new one on top of the existing one.
- Replace: Replaces the old one with the new one.
- Append: Adds the text of the new one to the text of the old one.
- Cascade: Places the new one offset from the existing one.
Show me what this looks like
- In the Sticky Note Protection property box, specify the rights for who can view and modify the sticky note.
- Public: Anyone who has access to the document can view and modify public annotations.
- Protected: Anyone who has access to the document can view protected annotations, but only the user who created the annotations can modify them.
- Private: Only the user who created the private annotations can view and modify the annotations.
- In the Add Sticky Note To property box, select the Laserfiche document you want to place the sticky note on. Learn more about selecting an entry.
Tokens for Add Sticky Note Activity
| Name | Description | Sample Syntax |
| Annotation_Id | The sticky note's annotation ID number. | %(AddStickyNote_Annotation_Id) |
| Annotation_Page Number | The page number of the page to which the sticky note is added. | %(AddStickyNote_Annotation_Page Number) |
| Annotation_X | The X coordinate of the location where the sticky note is added. | %(AddStickyNote_Annotation_X) |
| Annotation_Y | The Y coordinate of the location where the sticky note is added. | %(AddStickyNote_Annotation_Y) |
The "AddStickyNote" portion of the syntax changes to match the activity's name.
Note: All non-alphanumeric characters, except underscores, are removed from the name. For example, if you rename the activity "(Note) Progress!", the syntax for the Annotation_Id token is "%(NoteProgress_Annotation_Id)".
